Spinnaker 23.5
Mike B.
I want to install a spinnaker on my 23.5 The mast does not have a spinnaker block installed. Can anyone tell me exactly where,and how to attach one ? Thank you in advance, Mike
Rick Webb
Call Hunter
They can fax you a diagram for the halyard, cleats, and winches you will need. I think it may have been in the photo forum at on time might check there as well.
C
Crazy Dave
I know who to call
If your mast is a Z spar, then I suggest you either email or call Julian Crisp at US spar and he can tell you the location. Usually it will be about 4-6 incesc above the forestay attachement. Sounds like you have one of the early boats.
Sean Coerse
Spinaker
It's very easy first is your boat equiped with a furler. Second do you plan on using an asymetric or symetric spinaker
Mike B
Spinnaker answers
Thanks for the responses but no one answered my original question. How do you attach the block to the mast ? i.e. rivet/bolt it in place? What's the difference in asymetric or radial ?? Help............
Rick Macdonald
Crazy Dave
My 1995 H23.5 has an unused sheave in the mast just an inch or two above the forestay attachment. (The jib halyard is an inch or two below.) Is this for a spinnaker? I'd like to use it for a jibsock, but I don't see any exit point for a line on the lower part of the mast. Does that sound right? How would it even be used for a spinnaker? ...RickM...
Rick Macdonald
But there is no halyard exit at the bottom
I don't get it. Where is it supposed to come out?
Rick Webb
Check This Site
You should be able to pick up the parts at any chandlery but here is a picture. The US Spar part number you need is 1630 Item: halyard exit delrin SMALL Part No: 1630 Price: $2.86 http://www.usspars.com/section_frame.asp?Section=Z190
Rick Macdonald
OK, I see
So, I need to cut a hole then. I thought I was blind or daft and just didn't see where the halyard might come out. Funny that they installed the top sheave but not the bottim exit. I'm really only looking for a way to hoist the jib sock that I ordered. I'm hoping I can just flip the main halyard around the spreader and use it. With the fractional rig of the H23.5, that might work.
Rick Webb
From the Manual II
Spinnaker halyard exit is 1.5" above the forestay. There is a diagram in section VII of the owners manual. How you attach the sheeve will depend upon which one you buy. Check the attached link for the US Spars hardware. I would go with an internal one but an external may be easier. A spinnaker needs to be outside the forestay so the jib halyard will not work. I have a spinnaker on my want list as well. Seems most folks go with an asymetrical on these boats. Hope this helps http://www.usspars.com/section_frame.asp?Section=Z190
