I'm looking to add a spinaker to my sail inventory but i'm not sure what the proper dimentions should be for a H34 with a 51ft stick,if someone could enlighten me I would appreciate it very much.
Brent, if your spinnaker is the standard symmetrical, it should be @ 46'11"on the luff and leach, and 24' 9" at the mid girth. The standard formula for the luff is:the sum of "I" squared + "J" squared, (2437.7) take that square root,(49.37) multiply that by .95 (46.90')The girth is 1.8 times the "J" or 1.8x13.75 = 24.75'the standard pole length is the "J" dimension.Hope this helps, Mark.
51 represents the height above the waterline and has no bearing on any of the sails. your stick is 46 feet and it is the J, I, P, E dimenstions that dictate the calculations for legal racing sails or cruising sails that will perform well for your specific needs as discussed with your sailmaker.
