Spiinaker Options for Morgan 32
1,857
- -- -Bayfield
Your choices are a conventional symmetrical spinnaker used with a pole or a cruising asymmetrical spinnaker used without a pole. I use both. I wrote a rather long dissertation on the use of both a while back. It was quite long. See if you can find it and then you will gain the basic info on both.
Jun 25, 2006
22
-Morgan 323 Port of Everett Marina
I have a wisker pole but no spinnaker pole so maybe the asymmetrical would be the answer. I will look for your article. Thanks
Feb 2, 2009
2
Morgan 321 St. Petersburg Beach
I just bought an '81 321 that came with an asymmetrical "crusing shooter" in a chute - but no pole or other gear. I bought an ATN Tacker, will rig a downhaul. I expect that will be a fairly simple, easy to launch/douse and control system...will get back with you on that after I've actually tried it out...
