speedometer not reading
jco789
Jun 21, 2004
12
Hunter 326 somers point, new jersey
raymarine transducer/ seatalk instruments- the temperature reading is correctly displayed but even when I manually spin the impeller there is not speed record reading. any ideas?
Bob V
are you spinning it fast enough?
when you say you are doing it by hand i wonder if you a going fast enough. I would use an air compressor with a blower or a water hose to spin it.
Jun 6, 2006
6,990
Try the log setting
turn the knot meter to it's log setting and reset the trip meter or note the distance traveled and then spin the paddle wheel for a minute or so. The wheel has to be spinning pretty fast to show even 0.1 knots.
W
Warren Milberg
Lots of potential candidates for
this situation. I would think it is probably corrorion in one of the connections, or corrosion inside the wire connector itself. You may be able to check the continuity of the connection wires with a VOM. Also, if your paddlewheel is the type with magnets attached in few places, make sure you have all of them. Good luck.
Sep 24, 1999
1,511
Hunter H46LE Sausalito
time for a new transducer
you don't need to spin a knotlog fast to get a reading. a simple flick of a finger will do. if it doesn't respond, it's worn out.
