Under Propped
I agree with most of the responses to this post that you are probably under propped.I have a Vision 32, weight of 11,400, and 24 hp Yanmar diesel. My boat will do 5.8-6 knots at 2000 rpm, and 7+ knots at 2800 rpm. This has been confirmed by both calibrating my knotmeter over a measured course, and by using my GPS. This gives me plenty of reserve power for when the waves and wind pipe up. I've needed that reserve power a few times. Once, when I could only keep 3 knots of headway during a bad storm on the Chesapeake, and many times trying to break out of pier heads into open water during periods of high waves on Lake Michigan. Both of these are extreme challanges, but are encountered once in awhile.I had to change props in 95' when my old prop was attacked by galvanic corrosion and badly damaged. I ordered a new 17x10 prop from Michigan Wheel. It had a lot less thrust than the older 17x10 prop that came with the boat(I could barely make hull speed under full power/no wind/no wave conditions), and I questioned whether they sent the correct prop. I was assured they did. The next time I pulled the boat, I checked the new prop against the old prop, which I now use for a door stop. It was the correct diameter and pitch, but the old prop had a much wider blade, which accounted for its greater thrust. I had the new prop re-pitched to a 17-12, and I have my old performance back.I wanted to point this out to show that there can be additional factors that can also affect proper operation and speed under power. Also, don't assume its correct just because it came from the factory that way.I did some calculations on HP vs weight for recent Hunter 29's thru 33' models. All of the models thru 32', except the Vision 32, used the 2GM20 engine with 16hp rated, 18hp max output. Starting with the Vision 32, and the recent 33 footers, all used the 3GM30 engine with 24hp rated, 27hp max output.The following are the calculations:Hunter 29 -7400# - 463#/HPHunter 29.5 - 7000# - 438#/HPHunter 31 - 9900# - 550#/HPHunter 310 - 8500# - 531#/HPHunter 320 - 8550# - 534#/HPHunter 326 - 8300# - 519#/HPVision 32 - 11400# - 475#/HPHunter 335 & 336 - 11000# - 458#/HPWhile many other items factor into boat speed, it does give a general comparison of how like boats should behave. Since, by throwing out the two extremes, all the other boats have #/HP ratios that are within about 15% of each other, and my Vision 32 reaches hull speed easily at 2800 rpm with a 20% reserve in rpm's, I would conclude that all of these boats have adequate power available.I would consider re-pitching your prop for better performance.
