speed of a Mac 25
Ramblin' Rod
Dan, you're arguing a moot point...
As previously stated, your initial illustration was correct, but it didn't illustrate as clearly as the animation, that the net displacement of water particles in the wave is zero. To continue to ask that the old (or new) illustration be printed and viewed to confirm what is already agreed upon is moot, so lets move beyond that issue. The key issue at hand, that has yet to be resolved, is that the basic premise that this particle motion is what causes the vessel to exceed hull speed is flawed, as indicated by the number of conditions detailed in my previous post, where that model doesn't fit reality. If you wish to continue the debate, I suggest you address those points. Fair Winds
Ramblin' Rod
Chris - Surfing when other than DDW
Hi Chris, Yes it is certainly possible to surf on other points than dead down wind. First, wave direction and wind direction are not always the same. The ability to surf is dependant on the wave direction with respect to the vessel direction. Second, you can gain speed benefits from a following wave, anywhere up to just before beam to wave. One other thing to consider, and I'm not saying this is so, but 7.4 mph = 6.4 knots. Is there any possibility your GPS is/was reading mph vs knots? (I keep my GPS in mph units (and convert to knots as required), as we are generally sailing inland lakes and miles are often listed as statute miles on charts.)
w0nko
May 3, 2005
37
- - Beavercreek, OH
surfing closehauled
My best sailboat surfing was this summer on the Ohio river. I was making my way downstream (current was less than 1/2 knot) closehauled on the port tack. I was passed (astern) by a large downstream-bound tug with a HUGE consist. I surfed his wake until I was close to the N. shore, then went to the stbd tack closehauled and surfed the rebound of his wake all the way across the river. I rode some of the same waves twice!
Dan McGuire
Rod
The forward part of the the wave is a stable area for surfing. If the boat moves too far forward, the the water flow forward slows down and the boat moves back in relation to the wave. If the boat moves too far back, but is still forward of the crest, the boat moves forward. If the boat moves backwards too far, the boat loses the wave. Rod. The only explanation you have offered is "Instead, a displacement hull accelerate is due to the wind driven water wave modulating with the hull created bow / stern wave, which basically causes the motion of the two waves (not the motion of the water within the waves) to slide in relation to the actual water surface." I like my explanation better.
Nov 17, 2004
104
Macgregor 25 Three Rivers, MI
Rod...
I also keep my GPS in MPH, easier to know how fast you are going at a glance, no calculations needed. But, I converted it to Knots for this thread. I frequently go 8.5 mph, which is 7.4 knots. I guess I must be surfing. Chris M25 Chara
Dan McGuire
Very Long Response
Sorry about the lack of explanation in my last posting. I was somewhat shocked to find out that you suddenly agreed with my diagrams, even though you did not like them. I will address your comments one by one. You said "As previously stated, your initial illustration was correct, but it didn't illustrate as clearly as the animation, that the net displacement of water particles is zero." After reviewing your previous comments I found the following "We ll, I hafta disagree that they are the same…". "That’s actually not a very good illustration." I guess I must have overlooked the part where you said "your initial illustration was correct". Likewise your statement "To continue to ask that the old and new illustration be printed and viewed….etc is moot, so let's move beyond that issue." Again I fail to see where you agreed to anything prior to this particular response. You state "..that the net displacement of all water particles in the wave = zero, and that’s a pretty important part of this discussion." The net displacement is zero. All of the particles just go around in a circle. My contention was and still is that there is a forward motion of the water in the crest as seen in my diagrams. It is not always the same particle. The "old" particles fall behind the wave to join a new wave and to be replaced by new ones. Also this would tend to be true even for a sailboat, or just about any other boat which is small enough to be moved around by the wave. There would be no net movement of the boat. What makes the sailboat different is that it is moved forward propelled by the sail. Since the water is moving in the same direction as the sailboat, but slower than the sailboat or wave, it does not get an added boost, it just has to move at a slower speed relative to the water. You state "..if the vessel is in the trough between the waves, that the net water particle direction is opposite to the direction of the wave, AND surfing vessel." That is absolutely true. I failed to realize that the surfing took place in the trough. Never having surfed, I assumed that the surfing took place on the crest and leading edge of the wave. You state "Additionally, that the vessel doesn't accelerate dramatically when the vessel and the wind driven wind direction is opposite, when the vessel is in the trough (region of the particle motion moving in the positive direction), also contradicts the direct particle motion impact theory." This is obviously not talking about surfing. What you have is a boat moving at, say 6k moving through a wave moving the opposite direction at, say 10k. That would be a 16 knot closure. With a wave almost 56 feet long (required for a 10k speed), the boat would be in the counter flow less than 1.2 seconds. That is not a lot of time for the boat to do anything. You state "If this were the case (referring to the flow of water on the surface water), really light objects would be swept away by even small waves." That is not true. A small object including a boat, not aided by the wind or some other power, would rotate in a circle just like the "blue dot(s)" it is floating on. Even though the water particles in the top part of the wave are moving forward, generally they are moving slower than the wave. Thus, they move to the back and follow the rotation of the blue dot. You state "Whereas, if the acceleration were due to water particle movement in the wind wave, when the full wave length is in contact with the hull, the net force would be zero, and the vessel wouldn't move any faster." I agree. If the boat is not riding the crest or the crest plus the top part of the leading edge of the wave, my theory breaks down. You further state "It does". If the wave length is about the same length as the boat, then there would be no benefit from surfing. You would be limited by the wave speed, except for very short periods. You state "The key issue at hand, that has yet to be resolved, is that the basic premise that this particle motion is what causes the vessel to exceed hull speed is flawed, as indicated by the number of conditions detailed in my previous post, where that model doesn't fit reality." I think I have addressed all of the issues you mentioned. In addition, the model is based the one you pointed out. All I did was clarify it and show that there is a wave induced forward current in the top of the wave. Where you appear to be hung up is that there is no net water displacement. The key is that that current at the top of the wave is continually fed by new water particles which move up and add to the current and then continue their rotation and form a counter current. If you remain near the top of the crest there is a forward moving current. You state "Instead, a displacement hull accelerate is due to the wind driven water wave modulating with the hull created bow/stern wave, which causes the motion of the two waves (not the motion of the water within the waves) to slide in relation to the actual water surface". Frankly I can't figure out what you are trying to say. Modulating means to adjustor adapt to a certain proportion, regulate, temper. The best I can get out of it is that the hull created wave reacts with the wind created wave and causes the two waves to slide in relation to the actual water surface. I would like to see a reference, link, or better explanation because I don't have a clue how that explains anything. You state "However, that the wind driven and vessel created waves modulate, to a higher net speed than the vessel wave alone, still holds water (sorry for pun), under all conditions, including the loss of rudder control." Again I don't know what you are trying to say. Also, somehow this lack of explanation also explains loss of rudder control. My explanation explains lack of rudder control. I am not sure how your explanation explains loss of rudder control. If your experience with surfing took place in the trough, then you were right. My model does not fit your experience. However, it would appear that a boat could surf on the wave crest and forward part of the wave and not be hindered by the counter flow in the trough.
Ramblin'Rod - Mac 26D - SeaQuell
Believe what you will...
Dan, The phenomenon that limits displacement hull speed through the water to THS is the bow and stern wave. Imparting incremental additional force on the hull, has little effect on speed. Because of this, your particle motion theory causing the increased speed falls flat. Doesn't work. The premise that the speed limiting stern wave modulates with the overtaking wind wave, to then make the speed limiting factor the net of the wind and stern waves, holds true under all conditions. Believe as you will. I'm sure that no amount of supporting evidence will change your mind from its current set.
Dan McGuire
Believing What I Will
Rod You state "The phenomena that limits displacement hull speed through the water to THS is the bow and stern waves." No disagreement. You state "Imparting incremental additional force on the hull, has little effect on speed." No disagreement. I would note, however, that my theory does not add any additional force on the hull. It does not change the forces on the hull. My theory says there is no additional speed increase in the water moving past the hull. As such the boat reaches hull speed on the water surrounding the boat with accompanying stern/bow waves. It gains its additional speed from the movement of the water within the wave in relation to a fixed earth. You state "Because of this, you particle motion theory causing the increasing speed falls flat. Doesn't work." You fail to describe why it doesn't work. You state "The premise that the speed limiting stern wave modulates with the overtaking wind wave, to then make speed limiting factor the net of wind and stern waves, holds true under all conditions." All of that may be true, but you have failed to describe anything. It is like saying that the earth's weather is caused by sunspots. It may be true, but the process by which it happens is completely omitted. Let me help you a bit. "The stern wave modulates with the overtaking wind wave and causes it to (disappear, get smaller, get bigger, fall further back, go flying off into space, something else to be described later (pick one)). This makes the speed limiting factor the net of the wind and stern wave because the stern wave has (disappeared, got smaller, got bigger, fell further back, went flying of into space, something else to be described later (pick one)). This holds true under all conditions. The proof of this phenomena is contained in the following (reference, link, a little bird told me (pick one))." As half baked as my theory is, at least it has some appearance of being understandable. You state "Believe as you will, I'm sure that no amount of supporting evidence will change you mind from its current set." That is not true. I am waiting on that supporting evidence. So far all you have said is that Dan's theory is not correct and Rod's theory is correct, but you fail to provide even a hint of how the Rod theory works.
C
Carl
Anyone sailing?
All this technical discussion over a $4k boat? Do you guys smile when you sail, or just make calculations.. Any newbies reading this site, please focus on safety, skill, and fun. Sail on!
Ramblin' Rod - Mac 26D - SeaQuell
Dan, re: your particle motion theory
Please review your onw illustration and how it does not support your particle motion theory. I have placed a displacement hull on the wave, where surfing normally occurs. Please note the net particle motion direction and surface flow. Zero or maybe even negative. So by your very theory you are defending, the boat should not speed up (and possibly even slow down) when riding a wave like this. You should start adopting the wave modulation theory. (BTW, wave modulation means that the waves combine to make a net wave.)
Dan McGuire
Rod
If the boat slows down, it will drop back to the area of the wave, where the particle motion will help. At some point it would reach a balance. That is what I was talking about earlier. That is a stable part of the wave for surfing.
Dan McGuire
Carl
I have spent the last day mulling over your comments. Mainly I have wondered whether your comments are worth responding to. There are several levels to upon which to respond. First of All. What does the price of the boat have to do with anything? I would probably do pretty much the same thing whether it was a $100K boat or a $4K boat. I suppose in your mind a $4K boat is not worth discussing. However, the same discussion would apply to about any boat limited by hull speed. Second. I don't think enjoying yourself while sailing and making calculations are mutually exclusive. I do both. I try to analyze where on the lake I might be better off depending on the wind and terrain and the direction I want to go. I mentally decide how long it will take me to get where I want to go. Do I want to go fast or do I want to get there quicker? Third. I don't believe the newbies need your advice. I am pretty sure they can decide for themselves whether the thread is interesting. If they are turned off by the thread, then they probably won't bother reading it. It certainly will not jeopardize their safety. Even if they don't learn anything about surfing, just the general discussion is probably worthwhile. Fourth. A knowledge of the environments in which you sail is worthwhile. I am unlikely to ever sail in surfing conditions. However, trying to analyze how this phenomena takes place is very interesting to me. Like most of us, I have an interest in many things in which I will probably never participate. Fifth. I read and participate in both this forum and trailersailor. I actually read part of less than half the threads. Probably about half the time I read only part of the thread, I actually read all of the responses. Roughly, that means I read a little more than one quarter of what is in the threads, darn I started calculating again. They just don't interest me. Even though I am not interested in the threads, I figure that the people who do respond have at least some interest and get some enjoyment out of them.
MArk
582 million knots!
Hey Scott, That's the maximum speed of your M25 as limited by the General Theory of Relativity (GTR). I'm sure that's not the answer you were looking for, but your question was not specific as to the conditions under which the speed would be attained. I'm pretty sure you meant to know the speed on fairly flat water being powered by sail and not: Surfing (sliding) down a wave; Planing with a 100HP OB; Falling from a 3 story building; Being launched from a catapult; Shot from a cannon; or even driven through space by ion propulsion. Seriously though, the maximum sailing speed could be as much as 8 knots for such a light boat by using a lifting chute... if the hull gets planing. The chances of this happening are improved if you strip out the stove, table, bedding, provisions, etc., to minimize the weight. Then find a 75 pound jockey to pilot the boat and be the sole passenger. This may not sound practical, but neither is surfing anything other than a canoe or board designed for that purpose. I'm not saying the boat won't surf, (think of jetsam) I'm just saying it's not a true measurement of the boat's sailing speed. As to the subject of surfing, most of what was posted here has some truth and, when considering the bow wave, has made me question once again why a multihull is not limited by the hull speed equation. Happy sails *_/), MArk
Dan, it is most common...
...to surf in the area of the wave that I have shown on your illustration. There's no falling back or moving forward to any great extent. This is the area of the wave that one can ride and remain in, quite stable, for minutes and even hours, as I and many others have done many, many times. This directly contradicts the theory that the particle motion in the wave creates a surface current that enables the boat to exceed THS. Your model dictates there should be no increase in speed or the boat should actually slow down. This is obviously incorrect.
Dan McGuire
Sounds Good
Since my theory is no good, we are back to zero. I have heard no other reasonable complete explanation. Of course there is the possibility that the model for wave in the link is not completely correct. It assumes the wave is symetrical from front to back, but it very likely is not completely symetrical. I have no way of pursuing that one way or the other. It is probably a good time to end it anyway since I am going to be unavailable for the next week or so.
MArk
You do the math!
Dan, Rod, Here's a link to a technical paper (PDF file) on sailboat surfing given at the 2nd Australian Sailing Science Conference in 1999. The math is fairly basic. (hardly any Calculus!) I particularly like the Froude-Krylov equation. The technique takes into account a tail wind which you can minimize to look at the surfing effects exclusively. Enjoy, MArk
Dave
Im Sailing, How About You
I'm Sailing, how about you, Im going to live until Im 102. Great point Carl, be safe, have the right equipment, make sure you know your limitations, and have fun, if you dont have a grin on your face, quickly head to the nearest dock and call it a day! Because that is the beauty of a Mac 25, its inexpensive, goes relatively fast, 7 knots under my inexperienced hands in a light to fair wind, and I dont have to pay to keep it at the lake, can trailer it there any second my heart desires. Dave
Now that is interesting...
Thanks for posting this. I've looked briefly for some good technical work on following wave theory and have never found any. These guys are are making some erroneous assumptions about the interaction between the hull generated and wind generated wave. Their problems with model accuracy when the wavelength is less than twice LWL would be fixed if they assumed a "wave modulation" vs "wave-riding" theory.
7
73mensailed on a '92 Mac 26s
Hull Sped
Conditions will alter hull speed...enough said!!! The rest is moot. Enjoy the sail!!!
Dan McGuire
Not Much That Helps
The treatment apparently had some very good results predicting boat speeds. However, there is virtually nothing that might suggest the mechanism which increases the hull speed. As far as doing the math, they do not actually include the math. That is all included in software which resides elsewhere. There was one statement which might provide a clue, but it is not specific enough. "The velocity of the yacht in the wave height of 0.6m fluctuates periodically, as it moves through different positions of the wave. In this case the wave is overtaking the yacht; when the yacht is travelling fastest it will be closest to wave celerity and will hence spend more time in this section of the wave." Like I said earlier, I will be unavailable for a week or so.
