Specs, Diagrams, etc.
Nov 17, 2012
86
Hunter 37.5 Cherubini Bayfield, WI
:D Just took possesion of 1980 H37 Cherubini cutter. It needs most of the running rigging replaced, but I don't believe the previous rigger used the correct sizes for the main halyard, main sheet, outhauls on Kenyon boom, outer shroud sheets(?) (I've never seen these before). Also; would like to have diagrams of floor plans, plumbing, tank locations, does it have a water manifold?
No owners manuel, did NOT get a walk-thru, the sellers were older and he was in poor health, the broker had a severly broken leg, so my 1st Mate, Mary JO and I were on our own.
It IS a very nice, solid boat, well cared for, mostly, some neglect from the past 4 years.
May 31, 2007
784
Hunter 37 cutter Blind River
Congratulations! Great boat.
Your "outer shroud sheets" I believe are your running backstays which come into use when using your staysail in heavier conditions.
Go to the store on this site and punch in the make and model. You will get a list of appropriate lengths and sizes of all running rigging components.
I believe all schematics which were supplied in the original owners' manual are archived on this site. Just do a search. If you don't find it, someone will chime in with the link I am sure. Very supportive group here.
