I have a question in regards to retrieving my O'day 25 C/B from the boat launch. When I retrieve my boat from the launch, I get the boat centered on on the trailer and I get the keel lined up with where it needs to be on the trailer. I have a winch on the front of the trailer that is the only tie that holds the boat when I retrieve my boat.
The problem is this: when I pull the boat out of the water there is not enough weight of the keel on the trailer and the boat wants slide back when I pull away. When the boat slides back, the winch actually gives slack even though it is in the locked position.
To cure this problem I place three draw straps on the front of the boat and connect them to the trailer after I position the boat on the trailer. I connect two straps to the port and starboard cleats and the third strap to the connection on the front of the boat that the winch connects to. This seems to provide enough hold to keep the boat from slipping as a I am pulling away from the ramp.
My question is, am I doing something wrong? Should the winch be enough support to keep my boat in place as a I pull away from the ramp? I ask these questions because I have looked at a lot of pictures of 25's on trailers and none seem to have the front straps like my boat has.
Help would be appreciated. I have searched the site and could not find any information on this specific problem.
