Special
18
balboa 22 Milton, FL
When preping the boat for paint I noticed the word "Special" on the port side near aft just below the painted line that runs the entire length of the boat. The only way this can be seen is when the sun hits at just the right angle. This word is at about a 30 degree angle and is script. Anyone got any ideas?
Joe
Jun 1, 2004
8,344
Sounds like your boat used to be named "special" and the previous owner had an adhesive graphic of the name placed on the hull....just below the sheer stripe. When those things are removed they will leave such a signature as you describe. It's a lot of work to remove it so the P.O. left that job for the next owner.
You might try the archives for removal suggestions.
