Speaking of Holding Tank Vents....................
Bob F
Where would I locate the holding tank on my Hunter 376? Is it up thru a stanchion, or outboard thru the hull?? Thanks. Bob
Dec 2, 1999
15,184
Usually thru the hull.
Bob: I have not seen all of the possible places for tank vents, but Hunter usually uses a thru hull for the vent. Most of the newer ones have a clam cover.
Feb 15, 2004
735
Hunter 37.5 Balt/Annapolis/New Bern
uh oh...where's Peggy....
doesn't she have a standard response for these questions?....;)
Jun 4, 2004
255
Hunter 376 Annapolis MD
in the hull
In the hull, on the port side, a few feet from the holding tank. Open the port lazarette and you will see the hose leading from the holding tank to the vent in the hull. Allan
Dec 2, 1997
9,011
- - LIttle Rock
Out a thru-hull.
If you run it into a stanchion, it'll cause you nothing but problems...'cuz the slit in the stanchion will clog up regularly...even when it's not clogged, there's so little air exhange that odor is inevitable. My advice: use a 1" vent line, which will require using a 1" thru-hull instead of a "vent fitting," and make the line as shot, straight and horizontal as possible.
