Scott
I just started one winter project. I removed my boom and brought it home to re-paint it in the basement. My original plan was to sand the small areas of corrosion (where stainless fittings are attached), spot prime the bare metal, then use Interlux Multithane Primer and Interthane Plus to restore the original black color.After removing all fittings, and sanding with a random orbit power sander, I was able to remove all the paint fairly easily (took a couple hours). After finishing with 320 grit sanding, the boom looks beautiful with bare metal.I never really liked my mast and boom in black, so now I'm thinking of changing direction. Do I leave it silver or should I paint it white? I prefer white.I'm leaving the mast up this winter and planned on taking it down next winter. I suppose I could go aloft next spring and sand it but that's not a job I want to do. So if I don't paint my boom black, it will look a little odd for a season.What do most of you guys prefer? Bare aluminum or painted?
