Sourcing Custom-Made Propane Hoses
615
Morgan 415 Out Island Rogersville, AL
I am nearing the end of a 2+ year refurb of my Morgan 415 OI. With the launch date of my boat approaching, I would like to start on the design and installation of an exterior propane locker and regulator and hook up my old (but worthy) propane stove. Specifically I would like to use flexible gas hose between the locker and stove. However, I do not know of any sources for the custom-made hose and fittings; also, I don't know how to specify the fittings. It would be wonderful if the gray-beards on this site would recommend a reputable source for custom-made gas lines, and, perhaps, recommend where I can go to read up on the best practices for accomplishing my project.
Feb 10, 2004
4,248
Hunter 40.5 Warwick, RI
In my city we have a welding supply company that will make up all kinds of hoses for all applications. They are my go-to for anything that is custom for propane. They have all the fittings, know what to use and where, and can crimp the ends properly. It is much more than just a propane refill location. Look in your local directory for welding supplies. Make a sketch of what you need with photographs of the stove input and tank, solenoid, gauge, etc, and have them design what you need and make everything to the correct length.
Feb 8, 2014
1,300
Columbia 36 Muskegon
Local industrial hose shop. Any decent sized city should have one or two around. I've used West Michigan Rubber here in Muskegon for propane and fuel lines. Made while I waited and only took a few minutes. Quality work and inexpensive.
All the fittings on my propane system are 3/8" flare which is a very common type used in all kinds of things. Yours are probably the same, but you can take the fittings you need to mate to into the shop to verify.
NYSail
Jan 6, 2006
3,187
Beneteau 423 Mt. Sinai, NY
I bought all new components including hose from defender a couple years ago. Have choice of hose length......
615
Thanks all for the replies. JamesG161, there is a clarkgasco place near my home port. I will give them a try.
I would be interested in hearing recommendations for a good deck pass-through that I could use on LPG hose that has pre-installed fittings on both ends.
JamesG161
Feb 14, 2014
8,106
Hunter 430 Waveland, MS
I use propane at my house, the local dealer will make it for you, to length and propane specs.
I did a propane distributor search for Rogersville AL and found them.;)
They are in the Propane Safety business! I am sure they have home (perhaps marina fuel dock service) refill or delivery to sell you their propane.:)
Tip: These companies will normally do a free safety inspection once a year!
Safety first!
Jim...
