Roger Blandford
I am working on leaking window on my 1981 Catalina 25. I have read all the threads and ordered the weatherstrips from Catalina Direct. Now the problem begins. the windows on my boat differ from what information I have read about in other threads. specifically:The window frames only split on one end verses both endsThe window appears to be glued to the inner lip of the outer channelThe only weatherstrip is a small rubber strip that fits between the outer channel lip and the glass.I called Catalina and Catalina Direct and they tell me that there is only one style window. In examining other Catalina 25's the window frame and glass mounting are different. Is anyone aware of a change in windows. Mine appear to be as old as the boat.Can anyone suggest where I can go to get this outer seal. A crosssection of the seal appears to be a bit like a triangle with one side extended about 1/8".
