Source for 1 1/8 SS Pipe?
Rick D
Jun 14, 2008
7,204
Any of you know an on-line source where I can get a piece of 1 1/8 X 1/16 SS polished tube? I am doing some splicing and need about a foot. If nothing else, I'll check Minney's next time I'm there but I don't recall anything more than an inch. Googled it but came up with nothing but wholesalers/suppliers. Same with McMaster.
May 11, 2005
3,431
Seidelman S37 Slidell, La.
Seems like
I think I have seen pieces of 1 and 1 1/8 tube at WM. I think if you only need a foot or so a good place to look would be someplace that makes biminis. Could be you could luck into a piece of scrap for free.
Rick D
Jun 14, 2008
7,204
Re: Seems like
Could be, but only 1" in their catalog. RD
Rick D
Jun 14, 2008
7,204
Good thought too, but only 7/8 and 1".
caguy
Sep 22, 2006
4,004
I can check at Industrial Metals for you in Sun Valley. They sell it cut sections for scrap prices. I was looking last year at some 1'' polished still in plastic 14' long that was going for a $1.65/lb. You're not that far from there it really is worth the trip for you besides if they have it and I tell you about it, it could be gone by the time you get there.
I've been going there since I was a kid, and it's still like a candy store.
http://www.industrialmetalsupply.com/?gclid=CJ7Zwru5gqMCFRX_iAodvxp2YA
Rick D
Jun 14, 2008
7,204
CaGuy, I looked but they only have inch and a quarter. I would certainly take a ride there next time I'm near the Valley, but no 1 1/8. I'm beginning to think Minney's is my best bet, and maybe a stainless fabricator like Garhauer.
Nov 9, 2008
1,338
Rick D,
Give it up. You won't find it like that. I've tried. However, look for spreader tubes on the riggers websites. There she'll be! How do I know? My spreaders are loose. Upon close inspection, the mounts are for 1 1/8" OD tube but the PO used 1" and a few wraps of tape. Go figure.
Jun 16, 2010
98
Lancer 25 Newbergh
Every one needs to check out this place it is The best place for pipe or any thing is mcmastercarr.com they are a real candy store
Rick D
Jun 14, 2008
7,204
Yea, but they be aluminum, no? Still, great idea to check with my rigger; I bet he'd know a local source.
Apr 15, 2009
302
C&C 30 Annapolis
1 1/8 pipe
As far as I know, that's not a size that's normally manufactured (at least in S.S.) I hate to say it but you'll probably need to get a piece of bar stock and have someone with a lathe turn it down for you. Either that or you might be able find a hunk of stainless or Aquamet prop shafting. That is made in 1 1/8!
Call a local prop shop. Shafting is sold in various lengths then cut and keyed to fit the application. There's a chance they may have a scrap section.
Rick D
Jun 14, 2008
7,204
Re: 1 1/8 pipe
Alex, it appears you are correct. I guess I'll have to do an internal splice with 7/8. Then I have to figure out how to make the splice cosmetics look sanitary. Anyone have an idea?
2,288
C30 Event Horizon Port Aransas
There is a specialty metal shop I buy small pieces of aluminum and ss at in San Antonio. Are you looking for solid bar stock or a tube? What gage(wall thickness) are you looking for?
The guys I use won't be in till Monday.
If you are calling around looking, ask for 1-1/8" tube not pipe, if the OD of the piece you are looking for is 1-1/8". 1-1/8" pipe doesn't actually measure 1-1/8"outside diameter, it's larger.
Rick D
Jun 14, 2008
7,204
I am looking for 1 1/8 X 1/16th polished SS tube to use as an external sleeve over 1 X 1/16th tube. I am cutting and extending a bimini frame. I can use 7/8 tube and go internally but then you see the cut line. Anyhow, no big deal. I'll go with 7/8 and an internal sleeve. Thanks!
