Main Furling System, w/o the sails!
Main Furling System, without the sails!In our home port don't hear this sound much.. Typically only in spring or fall when the season is over and mail sails are being taken off or before the sails are on. And, the boat is in the water. I can't believe the "clanging". I've been guilty of this once and it drove me so nuts, I came up with a solution. The next morning, I got some line (about the same length as the main halyard), some swim noodles and zip ties. I then cut the noodles in 16" lengths and then in half. Every 2 feet, I "zip tied" the half noodles to the line making sure that the "zip-ties" are interweaved into the line so that they wont slip. I also poked holes through the noodles with the "zip-ties" when attaching to the line. I continued to add half noodles for the length of the sail furling inner roller. I then attached the line to the main halyard and ran the nooddles inside the mast to prevent the inner roller from banging and hitting the inner mast. I keep this inside the mast throughout the winter and have no issues in removing the line/noodles. I can post some pictures if anyone is interested.The sails are off, and roller furling system is quiet.
