David Foster
Large areas of the engine compartment for the one-lung Yanmar diesel on our 1977 Hunter 27 have no soundproofing. My project this winter is to reduce the noise when using the iron genny by sticking soundproofing insulation to the cockpit floor, and all the walls of the compartment. I'll also renew the old foam on either side of the enginer, and under the entry step.One specific question - there are some open spaces on the starboard side leading to the cockpit locker, and behind the icebox. Should I mount the insulation on a marine plywood cover for the hole (the largest is about 6" by 18") or just cover it with the foam insulation? In any case, I will leave an opening for air flow, although there are several other air scources for the engine.But I'm also looking for you advice and experience - I have checked the archives, but didn't find much on the subject.Thanks in advance.DavidLady Lillie
