SOMEONE KNOWS THE OPERATION OF A BLACK WATER TREATMENT SYSTEM WITH MACERATOR
Apr 24, 2013
26
HUNTER 33 NOUMEA
we are the proud owners of a hunter 33 from 2005 fitted with a toilet water treatment system but which we have never used. No recovery system in the countries explored available. Today the ports of New Caledonia are equipped with a suction recovery system but we have no idea how the system that equips our boat works. Can someone help us? Thank you
Michel. One of the best resources I have found regarding this subject is a book offered for sale here on the site.
The lady is Peggie Hall.
Her book is the a useful tool to learn all about your sanitation system and keep it operating with out smelling like a sewer.
Hello Michel
A boat as new as 2005 almost certainly has a pump out port on deck. It will be about 3” in diameter and look something like this
The port for filling your water tank And the one for your diesel can look similar so make sure you know which is which before you stick the suction wand in.
Dec 2, 1997
9,011
- - LIttle Rock
I need a bit more information before offering any advice: I'm not sure what you mean by "toilet water treatment system." Is it just a holding tank that you don't know how to empty or maintain? Or is it a separate "treatment" device that "sanitizes" waste and flushes it overboard legally? If it is a treatment device, what's the brand name? If you don't know, I can identify it if you'll post a photo.
--Peggie
Jul 7, 2004
8,542
Hunter 30T Cheney, KS
The port Rgranger mentions can vary slightly. Some pumpout stations carry a variety of adapters. We have a set onboard but only one fits.
BTW, all caps signifies SHOUTING in forums.
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
..............fitted with a toilet water treatment system but which we have never used......................the ports of New Caledonia are equipped with a suction recovery system but we have no idea how the system that equips our boat works. Can someone help us?
Curious what your "toilet waste treatment system is"? If we know what you have we can provide some additional help.
The 2005 Hunter 33 manual excerpt attached (pages 58) shows your waste system layout for a manual and electric flush toilet. This might to obvious, but you can discharge your holding tank waste by vacuuming it out, via a suction recovery system as you described, with a vacuum system waste hose and nozzle inserted into the through–deck fitting. Optionally, you can discharge directly overboard by opening the thru hull-hull discharge valve downstream of the macerator pump, which I assume you already know how to operate.
... but to do that legally you have to be three miles off shore.
Sep 20, 2006
2,955
Hunter 38 Georgian Bay, Ontario, Canada
Very nice boat, we've had ours for 12 years. Most likely Jabsco toilet with manual pump. Flip the lever to add water, thru-hull for the water intake is at base of stairs, then flip the lever to dry and pump unitl waste gets to the tank. Usually 5-6 strokes once the bowl is empty. Waste tank is behind the access door in the aft cabin. Pump out vacuum hooks up to the deck fitting on the starboard side stern quarter. Macerator is located under the aft cabin berth and thru-hull at base of stairs. You open the thru-hull, turn on the Macerator breaker on the DC panel and activate the pump with the Macertator toggle switch to empty the tanlk. If you don't have the Hunter manual you can download here.
The Jabsco manual is here, assuming it's the manual version not electric.
  • Helpful
Likes: rgranger
Jul 7, 2004
8,542
Your opinion... and its's wrong. It means I accidenatly hit the "caps lock" with my left pinky while typing.
I won't argue this. It's not my opinion and it wasn't directed at you. Just Google "all caps shouting" and read for yourself. It's etiquette for any forum. Just general advice.
