Someone else's Capri 22 :)
HERSH
Nov 21, 2012
520
Catalina Capri 22 http://www.chelseayacht.org
"Call me part of the Admiralty." -- probably been called worse at one time or another.
In the meantime, interesting where he has the turning blocks. Not the standard position as the lines come clear back. Mine hit the hatchway top guide rails.
Or is that your Capri 25 cabin top we are looking at?
Hershey
shnool
Aug 10, 2012
556
WD Schock Wavelength 24 Wallenpaupack
Look further Hersh, not MY cabintop, the horizon! As far as me being called something... I was married before... the ex has called me everything, have at it calling me what you will, I am immune.
Catalina 310 278 Lyndeborough NH
Hershey
My Capri 22's turning blocks are set up very similarly. I took out the outer bolt of the turning block and replaced it with an "eye". I clip the halyards to the eye when they are not in use.
But originally I put them in there to use as an aid to steadying the mast when raising it. I attach load straps to the eyes and to an extra goose neck slide I had hanging around. The whisker pole doubles as a gin-pole - also steadied with load straps. The main sheet block is used for the mechanical advantage.
John
shnool
Aug 10, 2012
556
You know you guys had me totally confused, because I forgot how my cabintop was arranged on my 22... NOW it makes sense to me.
This is what my 22 looked like:
This was my Capri 25:
I hadn't realized the cabintop on the 22 was so short... but I guess it was/is.
shnool
Aug 10, 2012
556
yeah, that is a pretty old picture (shortly after I purchased the boat)... the mast was hugely out of true when I got the boat... took a while to get it right again.
Its OK, because eventually it was perfect...
