Solo mast raising
Timm R
Far more people have requested information about how I step my mast by myself safely ,on the water and without spending a fortune.I will try to post clear simple to understand instructions . I use a pole that has a large ring on one and and the other fits snugly around the mast base. I connect a double block on a swivel to about where the forestay will connect. On the ring is a snap shackle that routes the line from the double block back to a single block on the ring down to the double and finally going to the mast winch. At any of the big box stores are pulleys that are called "rope ratchets".There are rated in several differant sizes.I used the biggest I could find.They are rated for 150 pounds.Prices were somewhere around 9 or 10 dollars apiece.The ratcheting pulley itself connects to the stantion base.you could use the triangle plates that came with some of the Odays.I used them on both and found no differance.The other end of the pulley has a snap shackle and clips to the ring. The forestay also connects to the ring. The rope ratchets are only used to keep the pole centered.I simply snug them up to keep the pole centered.I use the halyard winch to ease out line when lowering and the winch handle to raise. IF I encounter a problem with a shroud catching on something or a turnbuckle getting cocked ,I simply cleat off the line and leave the mast base knowing that the mast isn't going anywhere.The "Rope Ratchets" themselves will only let line go one direction unless you lift a lever on the pulley and pull line through.
Tim
Questions
Hello Timm, This looks good, but I have a couple of questions: (1) How do you attach the pole to the mast? Is it bolted or just interference fit? (2) What keeps the pole from sliding up or down the mast? (3) How much does the mast weigh? (4) I tried a block and tackle arrangement on my O'Day 192 and couldn't keep the mast from pulling to the side of the boat where the rope was anchored. Any suggestions? (5) Where did you get the pole? Thanks for your advice. Tim
flyhop
Aug 8, 2005
150
Oday 28 Guntersville AL
Neat idea, but 2 questions...
What size boat is this? Is it keel stepped or deck stepped? Thanks.
Timm R 25 Oday
Some answers
Hopefully these answer will help. If you look in response number two you will see the pole is interferance fit with the mast.It can't slide up the mast as it will hit he halyard cleat.I saw a pole made that was wood with a cutout for the mast and had a ratchet strap connected to it.This would be an option if my pole ever started to move around. The mast Ibelieve weighs somewhere in the neighborhood of 70 or 80 pounds. This setup is used on our 25 Oday.The mast and hardware is much beefier than the 192.The rrope rachets that are connected to the pole and lead back to the stantions are what keep the mast centered. The pole itself I had from a previous project. I needed to figure out a way to safely raise and lower the mast byself as help is kind of hard to find at times. The big box stores sell square steel perforatd tubing that slide inside itself.This is probably what I 'll use next fall when I remake the gin pole. The mast is deck stepped.According to Oday the mast should be raised from over the front of the boat.We tried this when I went down to buy it.Even with three people it was hard to keep the mast from flipping off the front ogf the boat.
