solid core or wood?
Bob Favre
I am getting ready to install an in hull transducer in my '86 222, but I don't know if it is a solid or cored hull...does body know? I thought I might put it in front of or beside the 5 gal. water jug up near the bow...any coments.
G
George Chamberlain
Once you have picked out a spot...
...for the transducer, here's how to check it. Put the 'ducer in a plastic bag with some water. Place it on the deck where you intend to mount it. Make sure to wet the deck just a little to ensure good sound transmission. If you get a reliable depth (you can cross check by holding the 'ducer in the water over the side). If the hull is solid in that spot, you'll get a good reading. If not, you won't. On my O'day 22 I mounted the transducer inside the starboard quarter berth locker, all the way forward and inboard. I am planningf to move it aft because in rough seas even that location tends to come out of the water. Where you are proposing will do liikewise, I think, you may want to go aft a little. You cannot mount the transducer over the keel, as that will block it. I'm going to try the same storage locker locaion, but at the aft end. I don't think the keel/ centerboard will be an issue there. Some info I have seen warns that the keel will block the transducer when you heel, I think that is nonsense, becasue the transducer and keel are fixed in relation to one another - when the boat heels, the keel heels, and the transducer heels too. One more thing - I mounted my transducer in silicne, not epoxy. I sure am glad I did that, now that I want to move it.
steve hecht
transducer mount
On my boat I drilled a hole in the center after spot where the portapotti goes. I used a 1 1/2 inch or 2 inch hole saw[ don't remember now]. This gave me acces to the hull somewhat forward ,but in the center of the boat. The hull I believe is solid, and this is where I epoxied the transducer. I covered the hole with a strip of teak. By doing it this way ,Iwas able to run the cable under the floorboards,and when the boat heels the affect is minimized.
E
Ed Brown
solid fiberglass
perhaps my sad event can shed light on your quesation. Two years ago, while hauling my 222 out for the winter, I accidently punctured the hull (forward of the sink, below the water line). The repair was easy but I got to see how the hull was built. It's about 1/4" solid fiberglass/epoxy composite. I saw no core material at all. Good luck Ed
