Solenoid replacement
edroc
Jun 29, 2009
3
2 Catalina 30 St-Michel
Bonjour I'm new on this forum, I read a lot of article on starting problem, I think I have a problem with the groun on the starter solenoid. I would like to know which starter solenoid I have on my boat the one with the screws or the one with the studds.
C30 1982, universal atomic diesel 5411, serial number 302799, 11hp.
Eddy Rochefort
Welcome aboard, noted no one had answered you yet.
A source for information on your engine is: www.marinedieseldirect.com
Only you can determine what studs you have on your solenoid, but the link will tell you what is normally supplied.
If you have starting issues, the first thing almost everyone says is: Check the grounds and all of the connections. That's before you start ripping it apart and replacing stuff.
