I have a 2000 Beneteau Oceanis 36 Center Cockpit. The boat is nearly immaculate and I want to maintain the sole in the same condition. I believe the sole is a laminate and I need guidance as to what Varnish to use? Thank you!
I refinished the teak & holly veneered sole on my previous boat, a Hunter 33.5.. Carefully sanded to remove the old finish, down to bare wood. Vacuumed thoroughly & used a tack cloth to remove remaining dust particles. Used Daly’s Profin to reseal. Applied about 5-6 coats to build up a nice finish using ultra fine steel / brass wool to buff surface between coats. Was very pleased with results.I believe the sole is a laminate and I need guidance as to what Varnish to use?
