Solar Wire: I have a quandary involving the wire used to wire my solar panels. I did hours of research and finally purchased two Kyocera 140 Watt solar panels (which will mount on a SS frame constructed above the davits of our Hunter 38) and a Morning Star TriStar MPPT 45 amp controller. I will have room for an additional panel and the controller will if necessary, handle the additional load). Through several sites I obtained wire sizing charts and recommendations to maintain a 2% loss in the runs necessary. I therefore intend to run #4AWG from each panel wired in parallel to the Combiner. There each panel will be on a 15 amp fuse, (either could be shut down without affecting the other). Then I will run #2AWG to the Controller then onto the house bank (20amp fuse in line prior to battery). The house bank consists of two 40-1000 Crown batteries. Each battery reserve capacity is 300 min @ 25 amps. Amp hour Capacity is 20hrs = 7A and 140Ah, 10hrs = 13.2A and 132AH, 5hrs = 25A and 125Ah.
I am having difficulty finding wire. I need 84 feet #4AWG and 60 feet #2AWG. The #4AWG should be UV resistant. The questions I have are these.
1. Where do I obtain the wire? The solar panel sites do not sell these sizes. (see #2 legality)
2. According to ABCY and Federal standards as I read it, I am required to have stranded approved wire that is also color coded. I have been unable to find this size wire other than listed as marine battery cable or welding cable and it is expensive.
3. Is standard home store obtained stranded THNN legal.
4. What wire can I use, standard stranded wire or special marine wire, and where can I obtain it?
Mainsail, thank you. Your site, photos, and various forum advise was very helpful and appreciated in this project. This forum also has been a site of inspiration and gained knowledge for me, Thanks to all.
