Okay, so it's time to add some solar to my boat. For various reasons, I've ruled out rigid panels and am very attracted to the Renogy 100W flexible units. At 1/5th the price of the Solbians, I figure I can give them a shot and if they crap out after four or five years, I'll still have gotten my money's worth. I've got enough room on my sailboat's hard dodger for eight of the Renogy 100W panels and plan to install four in a T configuration with two panels forward and flanking the centerline and two panels aft and oriented athwartship, beyond the end of the boom. I generally have my boom pulled to the side when not sailing so it won't be directly over the spine of the T either. Nevertheless, it's likely that at least one of the panels will be shaded by the rigging for at least part of each day, so I need a system configuration that'll minimize the negative impact of shading of one or two of the panels at a time.
I was originally planning to use separate Genasun MPPT controllers for each panel to address the shading issue but they don't have a 100W controller so you have to buy their 140W controllers at $170 each, which quickly adds up. Alternatively, for about $530 I can get a Morningstar 60A MPPT controller which will give me room to expand with more panels in the future at no additional cost. In addition, it can be networked and monitored via my laptop, which a nice-to-have feature. If I go the Morningstar route, I figured I'd wire the panels in parallel with Schottky diodes to address the shading issue, albeit at the loss of a fraction of a volt from each panel at all times.
FYI, my house bank consists of 800AH of Lifeline AGMs (inherited from the previous owner), I'm charging with a Balmar-regulated 140A Delco frame alternator off the engine and a Magnum MSH3012M inverter/charger while at the dock. I seldom let the bank get below 70% SOC and usually have an opportunity to get back to 100% within a week. The objective of adding solar is to buy more time on the hook without having the run the engine.
Any opinions on the alternative solutions or the system plan as a whole are welcome!
Thanks.
Thanks.
