the hole truth
I've had the pleasure of installing both passive and active (i.e. night/day solar) vents. I will not have a boat without them, since they improve ventilation, reduce moisture/mildew, etc. For the first one, I bought a "hole saw", a little unit that goes on a 1/2 in drill that has a pilot drill bit built in, and a round cutter blade. This works VERY well, and you have the advantage of clean, straight holes every time. Because it is attached to a drill, you can control cutting speed and prevent overheating of the blade/material. They come in specific sizes, so the one that I got was also used for intalling multiple inspection ports and dorades, each time with the same satisfactory results. I just purchased a new 37 footer, and put in three vents in no time at all.
