Solar Panel
Dec 11, 2009
165
Oday 26 Central FL
If a solar panel is hooked backwards to a 12 volt battery, neg-pos pos-neg, will it drain the battery instead of charge it?
capta
Jun 4, 2009
5,101
Are you using a charge controller? I'd unhook them ASAP hoping no damage has been done. I believe they have diodes in the circuit which you'll need to check too, before hooking them up correctly.
Mar 20, 2012
3,983
no.. hooked up backwards they dont take power from the battery, unless something shorts out and draws it down. but you can do damage to the panel...
Dec 11, 2009
165
Oday 26 Central FL
It's just small 5 wt panel I keep hooked to a DC battery. The battery is always topped of nicely from the Florida sun but this time way down.
