Solar panel
Oct 21, 2012
88
Macgregor 22 Lake Texoma Tx
I have a solar panel that I want to use should I wire it in on the hot side of the master switch so it will charge with the switch in the on or off or should it be on the up steam side ? If it go on the hot side it will charge all the time like when you are not on the boat
May 23, 2004
3,319
What size is your solar panel? Do you need a charge controller?
Wiring it should be directly to the battery. Charge controller will save you from frying your battery if you have a panel much over 5 watts. Try to get a MPPT charge controller.
There is a ton of information out there on solar panels. This site has a lot of it. Do a search and see what else you can come up with.
Oct 26, 2012
31
morgan 384 Tarpon springs
there are 2 kinds of charge controllers.
One charges the batteries all the time, and over charges them if not turnened off the other the more $$ turns off the charge when the batteries are charged..
I have a buddy with the cheeper charge controller and he ended up purchasing a new battery in the bahamas !
Oct 21, 2012
88
I will need to check the output it's on the small side I don't have a controller for it ,
