I was hoping someone built this and I could replicate it.
Basically I'm trying to build an extra shade on the back of the boat behind the Bimini. My Bimini was installed too forward so when you seating and steering you are not covered.
I'm thinking of building on to the existing rail extra vertical supports and then adding the solar panels and make them work as a shade. My solar panels are light flexible kind so not much weight so I thought I would build something out of PVC. Don't know if that's something that will be OK plus trying to figure out how to attach a PVC structure to existing horizontal rails without removing them.
I even thought of using stainless steel tubing but again don't want to remove existing rail to attach new structure plus price is a lot higher than PVC. Anybody had any success with PVC type of setup?
