Solar panel support structure
A
Anonymous 64629
Anyone install several hundred watts of solar power on a 34? I'm going to put a bimini together w/ the panels between the split back stay. Any experience? Brad'at'gmail.com
Dec 7, 2006
1
- - Tolchester
Same here!
I just purchased a solar panel to charge my #1 battery in place of my wind generator. The problem is placement. I currently have two large panels attached to my davits and there is no more space. I looked at the bimini but thought it might interfere with the the use of the bimini as we often choose to sail without it in place. Am currently trying to locate a bracket that will attach to my wind generator pole if no ideas regarding attachment to bimini are generated.
A
Anonymous 64629
Solar bimini
Thanks for the response. I think I need more photos! What is the rough dimension of a panel? Is that a Hunter 34? Cheers- Brad Happy holidays
Jul 1, 2004
567
Hunter 40 St. Petersburg
Hey Brad
Here's a link to the vendor where we purchased our panels. It gives all the specs you need (including dimensions) for various panels. http://www.svhotwire.com/solar_modules.html Anthem is a 1985 Hunter 40 which is the bigger sistership to your 34. The panel mounting can be much the same.
A
Anonymous 64629
Structural interest, panels already purchased
Rick- I already have the panels, and am trying to figure out the best way to mount them. Can you send/post pictures of the details of the bimini structure please? I hadn't thought of mounting them abeam behind the back stay as you did, and I like it. What size SStubing was used? Cheers- Brad geobartman'AT'gmail.com
Dec 25, 2000
6,052
Hi Brad, a fellow skipper mounted his two...
panels on the outside quarter of his top pushpit rail, one on each side. He can rotate them up or down for maximum affect and he seems quite happy with them. He has a Pacific Seacraft Creelock 34. Terry
