Solar panel reverse current
Sep 10, 2012
231
Hunter 450 Gulfport, Florida
I am hardly electronically challenged, but I did want to verify before taking action! Is there any other reason for blocking diodes in solar panels other than reverse current? If the controller has reverse current protection can I strip all diodes out of the terminal connections. I ask because I have seen components that had ulterior motives for their existence. I am connecting three panels and ridding myself of unnecessary voltage drops would be a benefit, six diodes @ .7 volts is 4.2V gained.
capta
Jun 4, 2009
5,100
Since most solar panels I'm familiar with produce 18 volts DC or more (if going w/24 volt panels), why would you care about the voltage drop? The controller is designed to regulate the input voltage to a nominal 12 volts anyway.
Sep 10, 2012
231
Thats why the controller has to have internal blocking, if it didn't there would be no question.
Beneteau 323 Annapolis MD
From the other end, that's why solar panels have built-in diodes- to idiot-proof the panel.
Feb 6, 1998
11,772
Your panel has bypass diodes not blocking diodes. You do not want to rip out bypass diodes. The controller will prevent back feed at night....
Sep 10, 2012
231
Thanks for the link, I guess my concern revolved around the fact that we are typically talking small numbers i.e. less than twenty volts for a parallel connect so dropping four would seem to have an impact. I am just now building the solar system, I built the supports above the davits and the shortest is ten feet wide. I only have three 70 watt panels at present but wanted to be able to grow the farm in the future without a rebuild. I also factored in placement for antennas or what ever needs a mount. They are far enough out that shading would seem to be a nonissue. I am considering a series connect which would also increase the voltage having even less impact. Sometimes simple things get confusing!
Sep 10, 2012
231
There are three diodes in the connect panel one for 6v and two for the 12v connect, the panels are not new and I replaced one on a panel that tested open. I assumed they existed as blocking as they are high current devices.
May 24, 2004
7,228
CC 30 South Florida
I think it all works out in the wash. Diodes voltage drop or power robbing shaded panels?
Sep 10, 2012
231
The diodes I am referring to are in the connection box and there are only two for the 21 volt circuit. I don not remember the part number but hey are high current connecting between the pos and neg contacts
Sep 10, 2012
231
The link explained why I had it wrong I didn't realize blocking typically preceded controllers and was outdated good that I didnt get impulsive. Now I know.
