Solar Power
What you need to determine is how much current you will be drawing from the batteries and for how long. For example a radio drawing 500ma, or 1/2 amp for 4 hours would be a 2 amp drain on the battery. The solar panels are rated in watts.Which is P=I*E, or Power(watts) = I(Amps) * E(Voltage). A 50 watt solar panel is typically 17 volts. So 50(watts) = I * 17(Volts), or approx. 3 amps per/hour. A 50 watt solar panel would replace the 2 amps drained in approx. 40 minutes, under full sunlight. If the same radio was on for 24 hrs, 24*1/2amp = 12 amps drain. The drain could be replaced in 4 hours, under full sunlight, with a 50 watt panel. As for charging two batteries, look into a battery isolator which has a + input terminal for the solar panel or other source and two output terminals to the two batteries +. It has internal diodes which will maintain both batteries at the same voltage, yet as the name implies, isolates the batteries from each other. Any auto supply store can get one if they don't carry one in stock.Hope this helps,if not let me know.Sail on....Terry
