Solar panel
I have the panel you mention, and have had trouble with the regulator. The first one got a bit of salt spray and failed, and was replaced by JC Whitney. The second I mounted in a safer area, with an additional heat sink, but it failed as well (both times it would not charge). The problem with the regulator is that it shouldn't be exposed to temperatures over 120 degrees F, or the weather, so here in Florida it just wouldn't work when the boat was closed up in the summer. Anyway, ICP replaced the standard regulator with a 7w unit, and so far I've had no trouble. A note about the panel, if it is the glass unit with a plastic frame: though very durable it is assembled with plated screws. Replace them with stainless. Other than that the unit is an excellent auxiliary power supply, and ICP is a very reliable company. I've had the unit just over two years.Mark Majors/v LesismorH23
