K
KennyH
My battery has a switch to disconnect all connections while at the dock and not being used. Only the solar panel is connected. The battery goes from full charge to 50% down over a week with no other connections. The solar panel is putting out over 13 volts in the sun. Is it possible it is draining the battery overnight? Maybe the diode that suppose the keep this from happening has gone bad. It is a flexable solor panel that used to be sold by most marine stores. Probably about 10 watts.
