solar lights
34
hunter 19 slaughter beach
any body using solar lights on the boats
perhaps a solar mast light might be useful
and bypass the need to wire thru the mast
Clark
Jun 30, 2004
886
Hunter 280 Lake Guntersville, AL
You'd not get enough brightness to work as an anchor light. Davis (I think) makes an LED light that can be raised by the halyard at night and plugged into a 12VDC outlet somewhere in the cockpit. Anchor lights do not have to be 40' in the air to do their job. IIRC, 15-20 above the water is sufficient.
