Solar Charger
john jankovic
Is it OK to leave a solar trickle charger, with a blocking diode, connected to the battery while the motor (alternator) is charging the battery?
P
Philip Teter
Blocking Diode
The diode should be located to block current from any source from backfeeding to the solar panel. The connection to the generator must be between the diode and the battery, NOT on the solar panel side of the diode.
