Solar charger output
David King
I recently bought a solar panel from West Marine, the smallest in their catalog. It is for trickle charging the battery in my Hunter 26. I measured the output with two mulitmeters and got a 1 volt reading on both. Is this normal? I would have thought that it would be 12 volts; few amps, but 12 volts. Thanks for your reply (ies). David King
Michael
The solar panel should read much higher than 12v open circuit (as much as 20 volts) but under load should read 12+ volts (assuming it is not overloaded)
