Solar Battery Chargers - Any good?
bcwave
Jan 8, 2006
24
Pearson 26 North East River, Chesapeake Bay
It looks like I'm going to be on a mooring again this season. One of the least enjoyable activities I had last season was lugging my battery ashore to take it home and charge. I've since had the alternator(?) replaced in my Honda 4-stroke 8 hp outboard so that it should put out a charge to the battery, though I suspect it might not be sufficient to completely replenish after a day's stereo and depth sounder use. I'm intrigued by these 12v solar panels I'm seeing on eBay that are shipped on the dashboard of VW's and other imports, I presume to provide a trickle charge while the autos sit in the lot. Would something like that work for keeping a charge during the week while on the ball? Thanks!
Tony Litvak
VW trickle Chargers
I bought 2 VW trickle chargers last year and they definitely do the job. Over the course of a week, depending on weather conditions, my Battery is always refreshed. I think the best way to go is to get 2 units and hook them up to the battery (don't worry about the solenoid).
BarryL
May 21, 2004
1,126
Harbor Freight 5 Watt
hello, I have this unit http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=41144 It is a 5 watt unit for $50. Works great. Barry
W
Warren Milberg
Some of the Dashboard Chargers
... you mention are not meant to left outside in the cockpit or on the cabintop. Best to make sure before you buy one. I would recommend a minimum 5 watt charger that ICP and others make and sell for around $60. You are probably right that the alternator on your OB will not keep your battery(s) fully charged unless your use your motor a lot. So a solar charger, with enough output, would be a good option.
K
KEITH TAYLOR
SOLAR CHARGER
I ALSO HAVE A P-26 AND USE A CD PLAYER, DEPTH FINDER AND NAV LIGHTS AS WELL AS STARTING MY 9.9 ALL WITH A HOUSE BATTERY. I MOUNTED A MEDUIM SIZED FLEX SOLAR PANEL (11 W) MOUNTED ON THE SLIDING COMPANIONWAY HATCH AND IT HAS KEPT ME FULLY CHARGED WITH A 3 TO 4 SAILING A WEEK KEITH
C
Capt Ron;-)
Tropic top off
BC, It will work fine in the summer, but your winter is a bit barren back there. I used two, then one, I forget the wattage, 80 to 100 maybe (3'X 1') solid frame solar panels and even when down to the one, had plenty of juice on the hook for a month without using my engine. Now this was in the tropics...;-)
P
paddison P-30
good idea on the charger
I'm on a dock with no power and spend a lot of time on the hook, 2 years ago I purchased a solar panel about 14 x 14 and mounted it on the stern rail, it advertised a trickle charge and it has worked great. Both batteries are kept at full charge, The one you spoke of,I believe is not intended for use in the elements, I first purchased that unit, and after getting it home and finding it was not for use outdoors I returned it for the one I have now and I support it 100%. I leave my boat in the water for the winter, so we can take advantage of any warmer weekends hence the batteries are always charged. Good luck.
Feb 15, 2005
81
- - Island Harbor Marina, Palm Harbor FL
OK for outside?
BarryL - Is that Harbor Freight solar panel meant to be left out in the elements? How's it holding up for you? The product description indicates it's for dash or visor. Jack
