Solar Questions
Thanks for all the info, really appreciate it.It would be really helpful for someone to give me the solar panel brand and model they have had success with. I can’t seem to find one on my web search that looks like it can handle a marine environment well.Also, some that I have seen, have clip connectors which clip to the battery terminals. Does any one have these and do they work well?? Can you close the battery protective case over when using the clips? I would prefer to have wires which have a circular metal connector which would just slip over the battery lead post and then screw them secure with the wing nut on the battery post.From my meager needs on the boat, I just need a solar charger to keep the marine battery topped off when it sits in the slip. I only have the running/anchor lights and bilge pump on the boat and I sail during the evening and thus drain the battery throughout the season. Thus I need only about a 5 Watt solar panel.From info I got from the web site listed here: http://www.boatus.com/boattech/casey/30.htmThe guy suggests placing a fuse on the positive wire to the positive lead of the battery and locating it close to the battery. Sounds like some of you have done this. What kind of fuse do you use and where can you get.Again, thanks to all for your help.Here in Wisconsin we got 13 inches of snow and I should be out shoveling but I would rather think about warmer days and the upcoming sailing season.Cheers,Daniel
