L
LaDonna Bubak - CatalinaOwners
This is oh-so-hard for me to write...Finally had decent enough weather this weekend to start work on replacing my chainplates. Bad news. The coring is wet. It's not like it was completely unexpected but it's still a bummer. Luckily no apparent delam.I drilled the holes out at least double size & filled them with epoxy but have also been thinking of Git Rot, etc. If I let the deck dry out, it'll be fall before I can do anything with my boat! So my thought was to install the chainplates in epoxy then at the end of a long dry spell, inject the Git Rot. Any comments or suggestions?This should be a heads-up to all you older Catalina owners out there. There wasn't a speck of sealant on those chainplates, nor on any other single piece of factory installed hardware. REBED YOUR HARDWARE!LaDonna
