To any who could advise! I am planning to do small soft spot & gelcoat repairs on a new to me 1969 Highlander 20. I am unsure of the hull construction (built in the 1960s). Up to this point this most I've done was a repair on a Hobie 14, which I understand has two layers of fiberglass with foam core in the middle. For that I Drilled holes through the outside layer and filled with polyester resin. Can I just follow the same process for the Highlander 20? Is the construction fundamentally the same? Having trouble find info online on the boat's construction. I heard that some older boats have a different approach to fiberglass layering.
Video of the soft spot linked:
youtube.com
1969 Highlander 20 Soft Spot
