Hi Whit, soft decks?
For sure. These solid decks must have been some of the first glass decks ever built. My boat, along with the original grid pattern(which may have been an after thought after the first few came out) has had more bracing added. They broke most of the spans on the side decks in half by adding another little plywood deck beam between the existing. These builders were clearly in a new territory and used their wooden boat building experience to solve their problems. I wish they had used solid wood instread of plywood to build this little framing system, it would be nearly twice as stiff, plywood of course is only 50% wood in a structural direction.
A problem area is just forward of the cabin house. Some boats have had reinforcement added there as well.
All things considered, I think adding this extra bracing underneath is a good solution. It's not hard although alittle tedious but doesn't have to all be done at once. Solid wood would be better, epoxied and fastened and painted, it dissappears into the original stuff.
The worst area on my boat is on the aft deck. There was no way to add additional framing, no access. I plan to open this area up on both sides of the structure that anchors the aft stay. Once one or two areas are opened, I'll add framing and finish with a hatch or hatches for access and stowage. This area would make great stowage.
I don't think they will ever be as stiff as cored decks unless something like David has suggested be done. On the bright side, they don't suffer from the core rot so prevalent on older glass boats and this simple additonal framing makes them stiff enough.
Whit, tell us about your boat. Thanks Tom
