Snap Shackle rather than locking halyard shackles
NYSail
Jan 6, 2006
3,187
Beneteau 423 Mt. Sinai, NY
I am getting ready to replace halyards..... Often I see the jib has a snap shackle rather than a locking shackle. Is this due to the fact that back in the day jibs were hank on and removed often? I was just going to get all locking (Tylaska) as obviously they seems are secure but figured I'd ask the questions in case I am missing something.
Thanks!
Greg
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Snap shackles are a tradeoff. They aren't as secure or as strong as a locking shackle, but they are much much easier to use. So for headsails that traditionally need to be changed regularly snap shackles are a better option. Snap shackles are subject to corrosion so need to be inspected on some frequency. They risk opening all by themselves, when the wind blows hard..............exactly the time you definitely don't want them to. Where you do not remove the head sail very often a locking shackle is a more reliable option. My two cents.
Jun 21, 2004
3,205
Beneteau 343 Slidell, LA
My roller furled jib and main both have thimbles with captive threaded pins, similar to Dave’s photo. Have been problem free.
NYSail
Jan 6, 2006
3,187
Going with the locking shackles...... Regarding the swivel., my furling top car is two sections where the bottom rotates and top is fixed.
Thanks!
Greg
capta
Jun 4, 2009
5,092
I use snap shackles on the spin halyard and second jib halyard without any problems. On the main and genoa U we use standard d shackles that we wire with monel to insure they do not come apart aloft.
An old company called Merriman Holbrook (I still have one if their winches aboard) that made marine equipment like snatch shackles one could trust their lives to, but unfortunately their gear was so good you never had to replace it, so they folded.
Point being nobody trusts the modern snapshackles to go aloft on, so why use them at all? stick with D shackles and monel wire, unless you are a racer.
Likes: NYSail
NYSail
Jan 6, 2006
3,187
Could not agree more.... I hate to fall. Main, jib and spare main halyard/topping lift all with locking shackles......
Tylaska
I met the engineer who designs and market these at the Annapolis Boat show. He was and interesting fellow. I liked the design. I would not be afraid to use one if I was in the market.
I, like Capta, have D shackles that I screw closed and safety wire.
Jan 21, 2009
260
Catalina 30 Lake Perry, KS
+1 for locking shackles on main and furling head sail. Wouldn't use a snap for going aloft. Maybe as a safety line but even then I tie a bowline.
