Dave
Saw it happen twice
IF your rig stays up you should head up and drop all the sails as soon as possible, evaluate the situation and make jury-rig repairs if possible.HOWEVER:A neighboring boat in my harbor had an upper spreader fail on a 3-spreader rig with a carbon fiber mast it 8 - 10 kts breeze. The entire rig came down in seconds and had to be cut away.Another boat (sistership to mine- Cat38) had an upper shroud fail at the lower swadge. The mast immediately folded over on itself at the connection point of the lower shrouds. There is SOOOO much synergy and balanced tension on a properly tuned rig that it seems to me that losing a shroud will often result in a failed rig.
