Tom M.
;-) never mind.....Seriously though Peggie, is it OK to use a snake to check for/fix suspected clogs or obstructions in the head discharge line to the holding tank or will that screw up the joker valve (new, cheap Jabsco). I had the gurgling head problem and don't think it is a plugged vent (I have two stern vents, one port one starboard). Speaking of joker valves, seems to me that the joker valve would prevent any head gurgling or spitting back into the bowl.Secondly, in another post recently, you mentioned that you cleaned out your holding tank (I assume rinse-pump, rinse-pump, rinse-pump until reasonably clean) then filled it completely full and let the water run till the water comming out the vent(s) in running clear. Did I hear you correctly? Thought that may work OK on a straight through thru-hull but may cause a clog in the clam shell type thru-hull (maybe not if the screen is removed...)Thanks as usual.Tom M.
