Smokey engine
54
Hunter 1981 30 Lake Travis
After motor sailing last weekend for about 4 hrs as I returned to the slip I started to lose power as I tried to increase speed. I backed off and the engine ran at the lower rpm fine, but as I tried to raise rpm it started smoking (white ) and rpms fell off. It stablized and after mooring I run it at high speed both fwd & rev no smoke no issues. Could it just been bad fuel or what?? I am at a loss, can't dup.
Sailm8
Feb 21, 2008
1,751
Hunter 29.5 Punta Gorda
I had a similar problem with a 1gm10. Turned out to be a clogged fuel pick up tube in the tank. Clog was caused by tank crap.
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
Sounds good to me
If it is reving up fine now, it probably sucked some junk up clogging the screen. How much fuel was in the tank at the time? You might want to check and change your Racor fuel filter. Is it a 2QM15? That is what I have.
You also may want to consider checking your impeller...to make sure it hasn't lost a vane or two that are now plugging your mixing elbow.
