Smoke from a YANMAR 30
361
Hunter 30 Middle River MD
Got many good suggestions from a previous posting about trouble getting the starter to engage, so I am hopeful that someone may have an answer/explanation for more my latest engine related mystery.
Saturday. was making for Cheaspeake City on the C&D from our slip on Middle River. For those familar with the Cheaspeake Bay north of Hart - Miller Island, coming from the Western Shore there are two ways north around Poole's Island on either its West or Eastern Side. On week days there is little choice as the Western side which should be shorter is off limits as its part of Aberdeen Proving Grounds range, however on weekends this area is open to sailors. I have never been up the west side route so we decided this was the day to do it. For the most part the course is wide with plenty of water however there is one tricky area where you need to come very close to the Island to squeek by a shoal.
That is were the problem occured. Being a rather green sailor, had both sails and the engine going, didn't want to lose steering if the wind dropped or came at me from the wrong way. Just as we got to the narrow spot the engine began to cough, missing and throwing up large amounts of smoke. None of the idot lights came on for oil pressure or overheat and having recently rebuilt the panel I know they all work at the moment. First I gave it more fuel it continued to miss then I put it into Neutral and slowed it then we tacked out of danger of grounding. I didn't want to cut it off but was getting afraid it might be damaged if I didn't. The engine is a YSB - 12 and has run flawlessly other than after I tried to feed it some water after a rough ride that stirred up the tank, which required my learning to bleed the system, and a problem with the starter which I am still working on. Just as I was going to kill it the engine smoothed out and then the smoke stopped. I let it run a while longer putting it back in gear after about 5 minutes start of problem to finish.
My best guess is something got by both filters and gave it indigestion but wondered if there could be any other problems. Fuel and tank look good but this is a very old rig so I realize there could be dirt anywhere in the system.
Had a rough ride back yesterday which should have stirred up the tank and found no water in the separator so it isn't the water problem again. Going back over tomorrow afternoon now that it has sat a while to make sure there isn't any water showing.
Ideas?
Dec 19, 2006
5,836
Hunter 36 Punta Gorda
Bad Fuel
Well you said it very old boat and sounds like maybe water got sucked in because it did get better and not shut down being clogged with dirt but it could also be dirt,my bet either water or dirt so check both filters and change any way and check the tank for build up in the tank and now loosing up,just my 2 cents.
Nick
Nov 6, 2006
10,253
Nothing in prop lke line or weeds? Smoke like that is telling you that the RPM has decreased below the set point of the governor and it is pushing in more fuel than can be burned in an attempt to get back to set RPM.. the air filter which we've talked about on the forum might be deteriorating and being ingested.. the injector may have had a bit of dirt or water, like Nick mentioned, that passed.. Water can do some bad permanent damage to the injector but usually it doesn't heal by itself. Good Luck .. Hard to find a problem that was temporarily there and no longer exists.. (See Toyota throttle runaway)
6,990
What color smoke
If she was missing then that would preclude any "external" loads causing the problem, if she was just overloaded then black smoke would be produced but no misfire.
Choose one, black, white, blue.
Feb 17, 2004
268
Hunter 30_74-83 Lower Salford, PA / Tolchester,MD marina
Diesel's hate water- reads like you pushed some through your system.
Also check your prop- from across the bay at Tolchester, mine loads up this time of year, but that will not cause the intermitant running.
Aug 23, 2009
361
Many thanks to all. Will be changing filters just on general principles and I will look at the prop. Checked the bottom a few weeks ago and it was fairly clean. Spent better part of a weekend in fresh water and it does really seem to scare the beasties off the bottom.
Ian had lunch at your marina a few weeks ago, seemed like a nice place and its certainly a good destination for a novice like me.
Again thanks all.
