Smell taking up residence
A
Andy
I am sorry to ask this question - probably the millionth time - but I was unable to search the archives, So..... - I have a 50 gallon Fiberglass holding tank (converted from water holding tank) that smells. I have tried vinager (sp?) and fresh water prior to leaving boat, and putting fresh water in the bowl after use, but even with tank pumped out there is still a resident odor. The hoses are all marine septic, what else can I try to remove the odor now (pumped out and ready for the hard) and during my use season? Thanks
Dec 3, 2003
2,101
Hunter Legend 37 Portsmouth, RI
Andy?
What Kind of smell is it? Stagnant water or holding tank smell?
David Williams
Bleach
Bleach will kill bacteria and eliminate their smells. You may also want to try baking soda; it works in a refrigerator
Dec 2, 1999
15,184
Bad hoses.
Andy: There is a good chance that the hoses are bad. They probably need replacement. Other than than you should check for any type of leaks in the tank.
Dec 2, 1997
9,011
- - LIttle Rock
Tank is almost never the source of odor INSIDE boat
'Cuz unless a tank is leaking, odor from inside the tank has only one place to go: out the tank vent. The exception: a worn out joker valve in the toilet will allow gasses from the tank to escape via the toilet. However, the odor will be concentrated in the head, not somewhere else in the boat. The most likely likely culprits are a permeated sanitation hoses and/or wet dirty sumps and bilges. Odors are always strongest at their source. So if the strongest odor is around the tank, make sure none of the fittings are leaking--if they are, re-bed them. Test the hoses for for permeation...a pumpout hose that's connected to the tank at the bottom will permeate first. If the odor about the same throughout the boat, clean your bilges--really CLEAN 'em, and flush ALL the dirty water out, then dry 'em out--instead of only dumping bilge cleaner and bleach into the primordial soup. You might want to check out the link below too.
A
Andy
type of smell
The smell is holding tank / head smell - even after pump out. My wife says that the smell is strong in the hanging locker where the hoses run from the head to the tank - so maybe there is permeation - I will replace the hoses and check the fittings/ thanks
A
Andy
Smell location
Thanks Peggy - I will check the hoses and fittings - the smell is also strong in the head - I will verify the valve while she is on the hard - head pumps out but there does appear to be back flow after pumping. How about fiberglass tanks - should I be concerned about the tank itself - I have seen no evidence of leaking. The hoses are the white septic marine hose - they appear fairly new (still shiny and rigid) so maybe checking the fittings first will make sense. The smell is not overpowering so I would think it is not leaking. The bilge is fairly empty (about 1 inch of water in ~3 ft deep well) and it is fairly clear so I do not believe it is bilge odor. Thanks again for your help.
Dec 2, 1997
9,011
- - LIttle Rock
Odor in the head can be a dirty sump
The odor escapes into the head via the shower drain. A dirty sump can smell just like a sewer. Backflow in the toilet, especially if the toilet starts to become harder to pump too, can be an indication that the tank vent is blocked, or partially blocked. If there's odor in the lockers the hoses pass through, that's a definite indication that the hoses have permeated. They don't have to be old...brand new hoses permeated on my own boat in less than 90 days. The same brand/type had been on my previous boat for 7 years without a trace of odor. As for fiberglass tanks...fittings have to be bedded, same as fittings and through-hulls in fiberglass anywhere else on the boat...and bedding compound has a finite lifespan. So I wouldn't be TOO concerned about the tank itself, but I would check fittings and rebed if necessary.
