JC
Here is a tricky one that has me stumped. I have a H 40 with a Link 2000R regulator/charger/inverter setup. The altenator is a Nielson 100 amp number. Problem is when the engine runs the alt (in charge or bulk phase) is putting out around 30 amps total. In time as the voltage rises it gets to 14.1 volts (gel cells) and switches to the accept phase. Out put amps in then increase to around 45 and gradually ramp down whilst holding to 14.1 volts as should be the case. Once charged parameters are met the float stage works fine.So the problem is it takes too long to get a full charge. I have had the altenator overhauled and no change.I have bought a new Xantrek smart reg and it does the same thing! I have changed the wiring harness.The altenator puts out full charge when the regulator is by passed by jumping the field wire with 12 volts.Any ideas?
