smart battery charger installed on Hunter 29.5?
Rick
Oct 5, 2004
1,098
Hunter 420 Passage San Diego
I have a 1995 H-29.5 with what appears to be the standard battery charger system. The charger is a Dytek brand charger, white in color but no helpful informtion on the exterior. I assume it's installed either at the Hunter factory or by the dealer. My question: is this a "smart" multi-stage charger or is it simply an oudated one that throws a constant charge into the battery system and eventually, if left running long term, would fry or shorten the life of my bank of batteries?
Jan 2, 2005
779
Hunter 35.5 Legend Lake Travis-Austin,TX
My '94, 35.5...
had a "Frytek" on it that I couldn't get off the boat quick enough. Pretty sure they are not "smart" chargers, mine sucked regardless, and since I'd had good experience with Truecharge 20 amp that's what I went with. I'm sure you'll get some better info. than that here, but that's my experience.
Nov 24, 2005
46
Hunter 29.5 Merritt Island, H 29.5, Miss Faith
Rick.........Xantrex
Truecharge 10TB is the choice for me............fantastic.
Mar 1, 2005
220
Hunter 34 North East, MD
Guest
I just replaced a dead Guest 2614 with another one because it uses three stages with "smart" technology for two batteries. It's a 10/5 amp output used for house/starting on two dual purpose deep cycle 27's. When in the slip on shore power it can "float" 12 volt use. Around $200.
