smallest 4 stroke motor for mariner
2
oday mariner 2+2 New York City
I have recently purchased a mariner 2+2 without an outboard and was wondering what size motor to buy. I would only use it in becalmed conditions. And it must be a four stroke. Any feedback would be much appreciated. thanks.
Jun 2, 2004
1,952
Oday Day Sailer Wareham, MA
If you only need it for days with little to no wind, and very little or no current, then I'd say a 2hp HONDA will do. They make it in a longshaft and it has a cetriugal clutch (no lever, when you advance the throttle it auto-shifts) and at under 30# it is a lightweight. However, if it were me, I'd tend more towards a Mercury 3.5 hp or even a Merc 4hp both (as far as I know?) are available with a longshaft and I think the 4 will have ,at least as an option, a remote fuel tank for greater range. Nissan, Suzuki and Yamaha all make basically the same outboards as Merc in these sizes. Honda also has a 5hp. All of these are 4-stroke outboards. 3.5 to 4hp seems to be what a lot of Mariners have, mant have a 6hp and some as big as 9.9, I'd think anything over 5-6 would be too much power to really use. Under 3 hp might be too little depending on wind/current.
Unfortunately, the Mariner 2+2 doesn't have a good, ventilated place to stow a fuel tank other than the cockpit footwell, but at least you don't need a bracket for the outboard, it can be clamped right onto the transom next to the rudder.
Another option is a good electric outboard, about 20-30# thrust or more. It might not handle a lot of wind and/or current but it calm conditions they work well!
I have a 4hp Johnson (2-stroke) on my DS II and feel that it gives me what I need with a definite "reserve".
Nov 17, 2008
32
oday 22 Buckeye Lake
I have the Honda 2 HP on my O'Day 22 and it does fine the lake. I have had problems with it though and you may want to check the archives for 4 stroke issues on small outboards.
